Hi all, not exactly new here, but it has been years, and username and password glitches kept me off, but I think I have it all resolved.
I posted here before about a 98 250 Foreman and you guys were very helpful. That one is still with me and runs fine.
Recently I bought a 86 TRX350 4x4. Has been very good so far, with one issue. On a ride with some friends the RF wheel started smoking. Long story short, the wheel bearings were loose and causing a lot of heat. I THINK this heat boiled some of the brake fluid because the front brake lever had zero effect and went easily to the grip.
Fast forward, I muddled my way through understanding how to get the front knuckle apart, but finally figured out the top ball joint has to be unscrewed. Very interesting design.
So yesterday, I installed the new bearings in the RF and started re-assembling the front end. I decided to try to get the brakes going again, and see if anything was ruined from the heat. That brings me here.
As FAR AS I CAN TELL there is no damage to the rubber parts in the brakes. Nothing leaks, but it acts like there is air in the line. I bled the RF for quite a long time, and I can pump it rapidly and get a solid stop, about halfway to the grip. It holds this under pressure. I tried adjusting the shoes and it doesn't seem to help bring the lever out nor keep from having to pump it.
I know bleeding the air from the Foreman I had a LOT of trouble getting the air out but finally did it.
Looking for suggestions on this new (to me) beast. Something I am not trying on these brakes?
Thanks
Thanks
