1 - 1 of 1 Posts
Rebuilt another petcock this morning using the eebae available kit. Worked out real well.
Check out the ripped gasket--the ATV continued to run for at least 10 min after I closed the unrepaired petcock--you can see that some rust bits coming from the tank probably cut the gasket.
The face of the lever had some deep scratches as a result so I polished it with some rubbing compound and shop cloth on a flat surface
1 - 1 of 1 Posts
