Is your front plastic mount cracked? The area circled in blue:
Well, you need my custom-designed and 3D printed reinforcement pieces! This is a perfect fit that allows you to reinforce the plastic mount from the underside. I failed to take a 'before' picture, but you can see where the crack was and what it looks like now in this picture:
I am asking $12 shipped for the pair. They are printed in PETG material, which is not biodegradable and will last a very long time.
I installed it by cutting a hole in a 2x4, then using weights to clamp it to the plastic with gorilla glue. See here:
https://www.hondaatvforums.net/threads/1986-fourtrax-350-fix-and-ride.102769/post-974457 You'll have to use something underneath as well, and a 2x4 works good for that too!
