1 - 14 of 14 Posts
hi,
when i hit my electric start, it just goes 'click click click' like a car when it has a bad starter solenoid. i have the new one, but can't find where it is to replace it. any advice? thanks.
bill
Should be right near the battery.
It's either, under the seat or under one of the rear fenders, above the rear tire.
rats
well, i got it installed, but it wasn't the issue. I thought for sure it was. :( there is a loud 'click' when i press the electric start button. there's plenty of juice from the battery cuz i even tried it while on the 'start' setting with the battery charger on. it definately sounds like an electrical component. any ideas what next?
thanks,
bill
mine did that it was just a dead battery from the key being left on.
If your battery is fully charged and all the battery cables and connections are clean, then, check your starter.
It still sounds like you arnt getting enough voltage to the solenoid it either has to be a bad connection. The starter wouldnt make that same kind of noise.
If the starter is bad, it probably won't make any noise at all, itself. But it can cause the solenoid to click.
good point justy jump the solenoid and see if the starter turns it over
1 - 14 of 14 Posts
