I have a rebuild kit and would like advice on replacing the needle jet. I see that it is not threaded. Does this part punch out? Is any heat required to aid in its removal? Thanks, TAGreen
It should just slide out from the bottom.
I think they're lightly pressed in, but it should pull out pretty easy.
Thanks Billy and Helmut, Just didn't want to ruin an otherwise good carb. I found that by using a little heat a stuck start valve can be removed without damage. They are somewhat fragile. Thanks friends, Alvin Green
