i recently purchased an old 85 honda 250 trx ....the gear shift lever is sticking in between gears ...any advice
I would do like I stated above. I would pull the left side cover off and watch the linkage as you try to shift. You should be able to see why the linkage doesn't turn the shift drum, unless it's an internal transmission problem. If you can't see anything wrong with the linkage, then remove the shift shaft and try to turn the shift drum with pliers. You will have to turn the flywheel some to get it to engage the gears fully. If you can't turn the shift drum with pliers, it's an internal problem. If you can turn the shift drum with pliers, something is wrong with the linkage.So what would it be in the linkage ? My 85 big red won't shift , so I am fishing trying to figure my problem out as well .
