The following Honda 38T cam sprocket part numbers are bolt-in interchangeable. Each are also known to fit all Fourtrax TRX300/TRX300FW motors when swapping in a ATC250ES/250SX or Fourtrax TRX250 camshaft (14101-HA0-000) and cam chain (14401-HA0-003).
Honda part number & year/model fit:
14321-HA0-000
1985 ATC250SX
1985 ATC250ES
1985 TRX250
1985 ATC350X
14321-HA0-010
1985 ATC350X
1986 ATC250ES
1986 ATC250SX
1986 TRX250
1986 ATC350X
1986 TRX350
1987 ATC250ES
1987 TRX250
1987 ATC250SX
1987 TRX350
1987 TRX350D
1988 TRX350D
1989 TRX350D
14321-428-000
1978 XL250S
1979 XL250S
1979 XR250
1979 XR500
1979 XL500S
1980 XR250
1980 XL500S
1980 XL250S
1980 XR500
1981 XL250S
1981 XL500S
1981 XR250R
1981 XR500R
1982 FT500
1982 XL500R
1982 XL250R
1982 XR250R
1982 XR500R
1983 FT500
1983 XL250R
1983 XL250R
I bought a used 14321-428-000 XR500 cam sprocket off from a seller on the fLeebay for this comparison with a worn out 14321-HA0-010 cam sprocket from a TRX350D. I felt confident when I risked a few $$$ on it that it might match up well with a 14321-HA0-010 but to be honest, its an even better match than I hoped for. It is a strong, very well made sprocket. I like it so much I'll probably swap an NOS one (if I can find one) into my 350D motor while its down for rebuilding.
Thickness of the two forgings measure identically at .250" The overall diameter and the pitch are identical. It weighs 10 grams heavier (101gm vs 91gm) having a .020" thicker cam attachment flange machined in and the forging has full-width teeth which an aftermarket D.I.D. TRX350D cam chain fit very nicely over, with chain links end play to spare. Those full-width teeth allow chain links more contact area on the outer edges of the sprocket while further enhancing the chain fit.
The outboard side of the -428- forging is unmachined, whereas the -HA0- sprocket has .010" machined out of it. On the inboard side of the flange the -428- is machined to .090" depth while the -HA0- is machined to .100" depth, which partly explains the -428- sprockets' .020" thicker attachment flange. Sure this lil' bugger weighs 10 grams more, but stability will be much improved and chain life should be extended as well, due to meatier teeth/full contact profiles.
Looking at the figures above we notice .010" difference is unaccounted for between the two identical thickness forgings. Well, that .010" was machined out of the -HA0- sprocket on the inboard side (just the sides of the teeth only, leaving a narrow band) which results in a narrower load handling area for the chain. In effect, Honda apparently took a -428- forging, weakened it, then slapped a -HAO-010 part number on it.
The -428- sprocket also shares the same centerline with the -HA0- once it is bolted to the camshaft, so its centerline hovers over the crankshaft sprocket centerline perfectly.
Installation Notes (updated):
The two sprocket mounting bolt heads will be rotating .010" closer to the head & rocker box castings when assembled. This should not be an issue on any motor since there is plenty of space available on all heads this sprocket fits. Normal camshaft endplay is very well controlled using the stock cams. But do verify that both bolt heads clear the castings with room to spare if you use the -428- sprocket. You can get that .010" back by grinding off the outer ring on the hollowed out mounting bolt heads if needed for your application.
All three part numbers have the same two mounting bolt holes drilled in them and one hole is larger than the other. One bolt hole (the uppermost hole when the cam is being installed properly, with lobes facing down) is about .280" diameter and is marked with a dot (.) on the outboard side of -HA0- sprocket part numbers. There is no outboard side dot (.) on the -428- sprocket forging identifying the smaller diameter .280" mounting hole.
The opposite (lower) mounting hole in each and every sprocket part number measures about .292" diameter.
So, the smaller diameter mounting hole should always be up when installing the sprocket onto the cam, whether that hole is marked with a dot (.) or not.
Also note that there may be more than one variation/revision of each sprocket part number found in various stock motors and NOS packaging. They may have been purposely interchanged on Honda assembly lines, because I see both -HA0- and -428- style sprockets that were bolted onto 250ES cams for sale on the fLeebay. I also have an NOS -HA0-010 that differs in appearance from the stock sprocket that was installed in my 87 350D... the one installed by the factory looks like a 250ES sprocket. Weird.... but since all three sprockets are identical except in appearance and outboard side markings (and slightly narrower tooth-tip radius machining on some of them), why not...?
Link to post and photos showing differences is HERE.
Conclusion:
Every one of these sprocket part numbers are identical-fit interchangeable, with the -428- being the most durably made sprocket of them all.
14321-HA0-000
1985 ATC250SX
1985 ATC250ES
1985 TRX250
1985 ATC350X
14321-HA0-010
1985 ATC350X
1986 ATC250ES
1986 ATC250SX
1986 TRX250
1986 ATC350X
1986 TRX350
1987 ATC250ES
1987 TRX250
1987 ATC250SX
1987 TRX350
1987 TRX350D
1988 TRX350D
1989 TRX350D
14321-428-000
1978 XL250S
1979 XL250S
1979 XR250
1979 XR500
1979 XL500S
1980 XR250
1980 XL500S
1980 XL250S
1980 XR500
1981 XL250S
1981 XL500S
1981 XR250R
1981 XR500R
1982 FT500
1982 XL500R
1982 XL250R
1982 XR250R
1982 XR500R
1983 FT500
1983 XL250R
1983 XL250R
Conclusion:
