ok the gasket on the float bowl is fixed but now its leaking worse than ever out the over flow hose. I have had the float bowl off 3-4 times and it seems to be working good. the choke cable will not slide back and forth like it should so I took it off and pulled it so it would be in the off position when reassembling it. I just cannot get to the bottom of the fuel leaking issue. anything im missing here folks?
