Hey, I was wondering if anyone could help me. I have a 85 350. Now it won't get fuel. I pulled the filters, still nothing. I hooked up the pump to 12v, and heard a noise, but it wouldn't put any fuel through... I am guessing the pump is bad. If I put fuel in the carb, it runs fine, just won't get fuel from the tank. I have heard that I can get a regular 12v pump from napa with a shutoff of 4PSI?
thanks
Chris
Just make sure the tank or petcock isn't clogged up with rust. You can use a regular 12v pump, but I do not know the specifics.
Welcome to the forums. I agree with Pain. I think Shadetree knows the exact pump to use, but I don't think he has been on here in a few days.
Didn't they have a primer valve system on those carbs? If they did check the primer it may be stuck or bad??
I don't think those carbs had the primer pump.
