Hi all,
Just bought a used 2005 trx350 FM, fourtrax ( rancher, i believe its called )
So i am having problems with it as the 4x4 doesn't seem to engage.
I got stuck 2 times the other day in the wood.
Once against a wood log, that it didn't want to climb as the front wheels weren't spinning only the back ones.
And once in a mud hole for the same reasons.
So i am asking you what can it be ?
what can i check ?
( i did check quickly the drive shaft between the engine and the front axle, when on neutral and turning that shaft by hand , ATV is moving back & forward as i'm turning it. )
I want to make sure to pin point the problem before changing any parts.
Thanks so much in advance for your help.
FAB
P.S.: also read about "warn 424 lock out kit" , can i install it no matter whats the problem ?
what can i check ?
FAB
