Tried starting my 2014 Rancher found that the battery was dead.This was after about 3mo. of setting. I put my trickle charger on it for about 2hrs with the cables from the four wheeler still connected. When I tried to start the four wheeler it almost started, then I put the charger to start and tried again. It started this time, but after I removed the charger the four wheeler died. I checked the battery and found that it was bad. I then installed a new battery and the four wheeler fired right up. I let it set and warm up for about 30min. I was driving it around the yard and decided to put it in four wheel drive. it would not engage, and no light was present on the panel view. Cable seems to work fine and I ran out of time and wasn't able to jack it up to see if the wheels are turning. Is there a possibility that I messed something up by basically jump starting it?
