just bought a rough 05 450r kicker for $1400. it runs but when im not reving it just stalls. ive adjusted the idle screw and i put on a Works Connection air/fuel mixture screw. ive adjusted both back and forth but no luck. it has fresh gas in it.
for some reason smoke comes out of one of the carb breather tubes and another tube that goes from the motor into the side of the air box. it has a full hmf and uni on it and i dont think its jetted.
i think the problem may be the air fuel screw because before i put the aftermarket adjustment screw on it idled fine. maybe this is screw is meant for a different carb? or maybe im not turning far enough or too far? please give me some advice and info on what i should do any try. i plan to clean the carb out tomorrow. please let me know how far the air/fuel mixture screw should be out. thanks alot.
