Looking at a TRX 400 that has a big bore 440 kit, from what I have read poking around the forum is there 440 big bores blow head gaskets like its their job, overheat cause not much material left to the cylinder and are not to reliable. I have read about a double oil cooler mod to make them run cooler.
The one I'm looking at has stage 2 cams with the 440. would it be possible to go back to the stock bore? I guess just buy a standard bore piston and cylinder? what about the cams?
Would it be more cost effective to do the double oil cooler mod to keep it running cool? or will I still have to deal with the blown gaskets.
This is the machine im looking at, can you guys tell what front shocks are on it?
