1 - 1 of 1 Posts
Hello,
I have a 2007 420 Rancher 4x4 es. While riding it shutdown for no reason and would not start back. With the key on everything shows up on the display as normal, but it will not change gears and when you hit the start button there is nothing. I have changed out the FI/Stop Relay, no change, tried a different battery, no change, tried jumping out the bank angle sensor, and checked all fuses. Also, I can manually jump across the starter solenoid and it will engage and turn for a few seconds, but there is no spark, also, the fuel injection does come on and work with the key switch like normal. Any suggestions would be greatly appreciated. Thanks!
1 - 1 of 1 Posts
