1 - 2 of 2 Posts
My hub was loose so I tightened it up and it was still loose so I replaced the hub but that didn't work either the splines are messed up on the axle. Just wondering how hard they are to replace or what all I need to do. I can do a little mechanic work but this will be my biggest job yet. If anyone has videos that would help too. Thanks
youtube for videos, or down load the service manual from our site here. pretty easy job. remove the left rear wheel and hub, right rear wheel and hub, brake drum, unhook brake cables, remove the rear brake backing plate ( 4 bolts or nuts mostly ), from the left hand rear side, a hammer, block of wood, tap the axle out to the right side.
1 - 2 of 2 Posts
