I have a 2013. Put new clutches in it about 200 miles ago and new cam shift drum and shift rod was bent. Also installed a 35% secondary reduction. Everything was working as it should. Changed the oil then it would pull about 30 feet then just stop. Turn it off the back on then it would go then stop again. Took it apart and put a new clutch in again and cleaned the main valve body. Still does the same thing but now you have to let it sit longer. When the clutch grabs doesn't slip. It's like it just lets go and doesn't want to engage. Any ideas
First step would be to run an oil pressure test, which means you'll have to either buy the tool (not cheap) or take it to a shop that has the right tool.
Download the FSM and see if it helps. You might have a blockage in your valve body on the upper front of the engine.
It stops moving. It's like the clutch disengages. Engine doesn't die
