1 - 13 of 13 Posts
So I have an 04 400ex and I just recently bought a Big Gun Evo. I also got an FMF power up jet kit. I talked to the people at Big Gun and they said the main jet is the only thing I need to change. (180-200) does anyone know what jet I use in the FMF kit?
180-200? What all is done to this quad? We need to know every last detail to get your jets sizes figured out. Welcome to the forums!
42 pilot jet. I would use the needle out of the fmf kit if there is an adjustable one. Go one clip down(pointed end being bottom) from the middle slot. And a 160-165 main jet. You will have to remove the carb from the quad entirely. Take the float bowl off and change the pilot jet. It will have a flat tip head on it. Under a little plastic baffle. The 42 pilot jet will make the quad start up alot better when cold. While you have the bowl off change the main jet. It will be sticking out further then the pilot jet and be a hex headed jet. Then put the bowl back on and remove the top to get at the needle. Since your quad is an 04 your stock needle may already be adjustable. If it is just drop the clip on slot. If not use the fmf kit needle that should be adjustable. To get the needle out you gotta remove the 2 phillips screws down in the slide. They will be a real pain to put back in without a magnetic tip driver. You also have to remove the bigger phillips screw and swing the whole thing out of the way. Getting the bigger screw back lined up with the shaft can be alittle bit of a pain also. Good luck and ask alot of questions if you get stumped.
Yeah I just put the jet kit in. I went with a 160 main jet and put the new needle in. Do I have to put in a new pilot needle or is that just recommended since it’s just the idle fuel flow? I’ve yet to put everything back together since I stripped one of the brass bolt. You were right about the 3 screws with the needle. Big pain in the butt. Hopefully everything works good. One more question, do I have to adjust the idling screw too?
The 42 pilot jet is just advised. Not 100% necessary but the quad will run alot better with it. They come so lean from the factory for emission regulations that any modification at all requires more fuel in all places. I would if your not going to up the pilot turn the mixture screw out about a full turn. That will compensate some but the 42 would be better. Btw i know your new here but we try to keep a family friendly forum here. We will edit your language from time to time. But if it gets excessive we will take action. Like i said though your new and i completely understand because most forums are not like this one. Any other questions feel free to ask away!
Reactions: retro
So I’m looking for a pilot jet, should I go with the Keihin 22 Series Pilot Jet or does it have to match with the FMF kit? If not, will the keihin work for my quad? After I get everything on, do I have to adjust anything?
Keihin 22 series. And no everything else should be good to go. You may have to fine tune the mixture a bit but nothing crazy.
Ask as many questions as you need! Thats why we are all here. When you are tuned spot on you will start easy first or second try and idle nice and smooth. It will rev clean and respond fast. You will have no popping or flame out on decel and the motor will not get excessivly hot. You should notice no bogging or flat spots in the power curve.
Did you try adjusting the idle screw? If you removed the carb completely you removed the throttle cable and that is almost impossible to get back on with the exact same adjustment it had before.
1 - 13 of 13 Posts
