I got the new 400ex Yesterday. I only got to go up the driveway since a tsunami has hit Missouri. Its falling flat on its face at higher RPM's. I believe its a tuning issue. Did an oil change, with filter. New air filter. I have a couple questions.
Question 1: Every time I pull in the clutch the neutral light come on. Is this normal? It's very annoying.
Question 2: The clutch lever is extremely stiff and very hard to pull. Its a stock clutch and lever also. My other 400ex was a lot easier to pull and use. Is there anything I can do besides get a new cable and clutch? I took the cable off and ran some WD40 down the cable, but it didn't help much.
Question 3: After driving 4 hours home with it on a trailer. I started it up and a TON of blueish smoke came out of the exhaust. Was this because of being on a trailer and oil got moved around above the piston? Is that a sign that I am going to need new rings?
Question 4: I got another header/exhaust from my buddy who I bought it from, it wasn't off this bike but it has a crack in the "header" I am very good at welding but this is really thin Metal. Has anyone ever welded something like this before?
I have more questions but they can wait. I didn't want to make this post too long. Thanks in advance for your good advice
