1 - 9 of 9 Posts
hey i have a 400 ex bored out it is a 1999 honda 400ex bored 40 over so its got the 440 big bore in it i looked at my piston number and it is 4667m but no other numbers i measured the cylinder any ideas of how i can order rings the local atv store says there is more numbers but there is not
if it's 40 over..then thats the size of the rings you need. count how many sizes there are from standard to that size..thats your ring size.
bored .040 dosent mean you have a 440 Kit though. fyi a .050 over piston is only a 85.50mm piston stock is 85mm now if it 4.00 that would be a 89mm piston which is a 440 kit. if you look real close on the top of the piston if it's a wiseco it will have the number stamped around the outter lip
ok i looked you have the first part of the number you do have an 89mm piston 4667MO8900 Piston. PK1041 should do the trick that's the complete kit.
well i called up wiesco and they said their has to be more nummbers but were they should be is coroded i have the 89 mm bore wich is a 440 and i ordered rings valve seals and a copper gasket kit because the stok ones blow out easy i heard
1 - 9 of 9 Posts
