I went through all the wiring and it's all good. I also looked through the owners manual (thanks
@retro) at the troubleshooting ignition section and it was telling me things like
Low peak voltage
No peak voltage
Peak voltage is normal, but no spark jumps at plug.
-How do I figure out the voltage of my Atv?^^
PROBABLE CAUSE
1. Incorrect peak voltage adaptor connections. (System is normal if measured
voltage is over the specifications with reverse connections.)
2. The multimeter impedance is too low; 10 MOIDCV.
3. Cranking speed is too low.
* Battery is undercharged.
4. The sampling timing of the tester and measured pulse were not
synchronized. (System is normal if measured voltage is over the
standard voltage at least once.)
5. Poorly connected connectors or an open circuit in ignition system.
6. Faulty exciter coil. (Measure peak voltage.)
7. Faulty ignition coil.
8. Faulty ignition control module (ICM) (when above No. 1 through 7
are normal.)
2. Short circuit in engine stop switch (blacklwhite) wire.
3. Faulty ignition switch or engine stop switch.
4. Loose or poorly connected ICM connectors.
5. Open circuit or poor connection in ground (greenlwhite) wire of
6. Faulty peakvoltage adaptor.
7. faulty exciter coil. (Measure peak voltage.)
8. Faulty ignition pulse generator. (Measure peak voltage.)
9. Faulty ICM (when above No. 1 through 8 are normal.)
1. Faulty spark plug or leaking ignition coil secondary current ampere.
2. Faultv ianition coil.
the ICM.
1. The multimeter impedance is too low; 10 MOIDCV.
2. Cranking speed is too slow.
3. The sampling timing of the tester and measured pulse were not
4. Faulty exciter coil (when above No. 1 through 3 are normal).
1. Faulty peak voltage adaptor.
2. Faulty exciter coil.
4. Faulty ignition pulse generator (when above No. 1 through 3 are
normal).
2. Faulty ignition pulse generator.
-I have all the tools I need, but i don't have all the testers that are involved with the electrical system that I would need to troubleshoot some of the things on there. Do you think I should just take it in to Honda? I know my battery isn't undercharged, but how do I test for something like a "faulty peak voltage adapter"?
-And I also wanted to mention... when I bought my new spark plug, it was in the box and I know it's the right one, but when I went home and put it in, the coil was not gripping it.. it was just sitting on the spark plug loosely if you know what I'm saying.. so I took the spark plug out and ended up screwing a little cap on top where the thread is. When I put it in the coil, it fit and was holding like it should. Do you think that has something to do with it? The spark plug that was in it before didn't have one of those caps screwed on on top. But I didn't do the last spark plug change because I just traded my old raptor 660 for my now 400ex last season.
