OK I need help I bought a honda 400ex and it has a lot of gas in the oil and I keep changing it every two weeks! When I bought it the carb was junk so I bought a replacement for really cheap and I compared the two and they look identical inside and out. And I tuned it correctly but it's a clean carb and I'm still dumping gas into the oil and I don't know why. The fuel shut off is shot and a new one is on they way will that fix it? Or is it something else?
It's not running rich but I wouldn't doubt the rings are shot because there was a lot of work done to it. I will do a combustion check on it soon
OK so it is not running rich and that is confirmed and the rings are not shot either because I got a compression of 137 psi I'm officially out of ideas and have no clue what's going on
