I had the same problem. Check the two wires that go to your headlights. You will need to remove the plastics. Chances are they are frayed like mine were. Good luck!have a 2001 400ex, keeps popping fuses when i turn on the brights, when the lows are on it flickers and when i get the rpms up the light dims wayy down. any ideas? i just got a new voltage regulator and battery, didn't fix it. electric start does work.
