I just recently purchased a set off widened a arms well I put them on yesterday everything went on perfectly but now my fourwheeler is pullin bad to the right I know theres a way to measure these can anyone give me some info or directions
Are your wheels both pointing straight ahead? You can adjust the tie rods to pull the wheels in or point them more out if needed. Also make sure your wheels have the same air pressure.
Rob
Yes sir they are its fine when im just easin around but when i start gettin into it, it starts gettin real shaky?
Could be bent rims, low tire pressure, do your aftermarket a-arms have adjusters for the camber and toe? If they do you may have that out of adjustment. Take a picture of the front of your quad and post it. That will help everyone out.
