I added a few things i came across on ebay for my 400ex. One is a oil dipstick with a temp guage in it. Seems to work really well so far and the machine work was top notch! And it uses a really high quality thermometer. The second one is a greaseable swing arm pivot bolt. I needed a new one since mine was wore out pretty bad and this one was only about 15 bucks more then a new oem one. And it is actually a oem one that they modify. So for 15 bucks you get a brandnew oem bolt modifyed with a grease zerk and cap on other side and small holes drilled in it. Should eliminate the bolt getting seized.
