1 - 9 of 9 Posts
Hi guys I have a 2006 400ex. I’m doing a clutch replacement, and it’s never once been opened up. I have tried everything from hitting it with an impact hammer to a crow bar on the fin, and nothing will take it out. The cover is just stuck. Can I have some help with what to do? Thankyou guys!
150209
Auto part Engine Automotive engine part Carburetor
only tap on the tangs on the cover, it will come off, dont stick anything in between the cover and case to pry on !.
Thanks for such a quick reply, I have tried sticking a screwdriver on the back and wedge it and tap it, and it still doesn’t come off. I don’t see any bolts that are still in either, do you?
no, i did not see any bolts you missed ?, take a long screw driver, rest it on the tangs, give it a whack with a hammer, then go to other tang, do same there, it will pop off, try not to break the tangs off !!.
Just a quick update, I went back down and did exactly as you said to do, still no luck.
your either not hitting it hard enough on the tabs ? ( i see 3 of them in your pics ^^ ), or you some how missed a bolt ?, if one bolt is still in the cover ?, it wont pop off.
I was able to pry it off with a pry bar, bent 2 screwdrivers 😂. It really appreciate your help man!
yw, i hope you did not scratch the sealing surface where you used the screw drivers ?..lol.
1 - 9 of 9 Posts
