Hi,
Working on a 400ex and it has what I would call a worn bearing sound when it is in neutral idling. If I pull in the clutch the noise goes away. Im thinking the bearing in the pressure plate? Any how while inspecting the clutch I noticed the gear attached to the basket has a little right to left play and the springs can be rotated is this normal? What do you look for as far as a bad basket. Thanks
