1 - 9 of 9 Posts
400ex breaks up around half too full throttle then will die. Also gas pouring out of overflow while running
Breaking up sounds like main jet too small or clogged. Did you clean the carb on it yet?
Not yet would that cause over flow too? But thats what he suspected
It shouldn't but if there is dirt in there to clog a jet, there is probably dirt in there to make the floats or float needle stick open.
Gas pouring out of the overflow means the floats are stuck or broken. Give the carb a good cleaning and see where that gets you.
fixed thank you guys he was posting for me thank you
The person we bought it from put the metal piece you slide the air filter on backwards soo it couldnt get any air!! :icon_ laughup:
1 - 9 of 9 Posts
