I have a mid 90's 400 four wheeler. I rebuilt the carb but now it starts and runs ok except when just part throttle it wants to miss or sputter. I have torn it apart several times blowd out everything and adjust air screw. What am I missing? Thanks
Check the clip on the needle to make sure it's tight also pull the pilot jet and take some torch tip cleaners and clean it out real good and spray carb cleaner through the passages. your Idle circuit is stopped up
I agree with Moose. Sounds like you still have a carb problem, maybe some debris still in the carb.
