1 - 10 of 10 Posts
Anyone ever seen a jet kit for a 1987 350D? I live in Colorado and will be up in the mountains with this ATV eventually and would like to jet the carb.
Talk to the local shop for advise about jet sizes. They usually can get you very close if not right on. Probably one size smaller on the slow jet and 3 to 5 smaller on the main.
I was paging thru the manual and it actually says to switch to a #132 main jet above 5,000 feet. Ordered one, hopefully I can get it and put it in next week.
I have one on mine–it’s a 138.5 actually–got it for $8. works pretty well except I don’t know how you change the jet without pulling the carb. So I have two carbs��
138.5 main jet I have the part number here somewheres
Oh you’re right 132. Don’t know why I used a 138.5 but it works.
I think because that’s the only size left in the shop box. Also I ride from 3000 to 5000ASL this jet doesn’t lean out the engine as much as the 132 might.
So try that same part number just use 1320 at the end
1 - 10 of 10 Posts
