I have a 2003 350 Rancher, manual transmission that has been sitting a while. I charged the battery and it started immediately. I tried it a couple of more times and then heard a spark like crack and it would not start anymore. The Neutral light will not come on anymore when I turn the key on, but the unit will start when I pull manually, although all of the lights blink.
Is this a battery problem or can someone please help?
Thanks
Hard to say, but you can test it with a voltmeter and see what it shows. It should show around 12-13v without load, and no less than 11.5v under load. Anything less than that, the battery is shot.
Thanks
I agree with Pain, check your battery. Also, check the battery cable connections to make sure they're clean and tight, because sometimes when you get a pop or crack like you're describing and then you loose power, you have a bad connection somewhere, usually at the battery terminals. I would take them off and clean them, because sometimes it's hard to tell if they're corroded or not, by just looking at them.
Well, checked the battery and it read about 5 Volts. Sounds like that is the issue. Thanks for your help.
Yep, sounds like that's the problem.
