Hello All,
I am having a problem with my 350 running to rich and fouling the plug in less than 5 minutes. I feel like I've done everything I've read to do. Cleaned and rebuilt carb with rebuild kit, adjusted valves, cleaned air filter and replaced the choke plunger and greased it so I know the choke isn't stuck. I was messing around with it last night and screwed the pilot screw all the way in just to see if I could get it to run lean and it still ran just as rich! That made me wonder if something else must be wrong. If I unscrew the pilot screw the engine doesn't seem to run any faster it just seems to kinda smoke a little more. What could I possibly look at doing next? Thank You for any and all help!
what year is it? running rich is not normal no matter what year. ya might have a vacuum leak. where did ya get your parts from? china part's will only cause problems, instead of correcting them.
