Can someone tell me the easiest way to diagnose what could be causing my battery to not hold a charge?
I invested in my first float charger, and it seems to charge the battery to 12.6V. , but not to 13.0- 13.2 V...and that was leaving it charging/maintaining for about 10 hours.
https://www.harborfreight.com/12-volt-deluxe-battery-maintainer-and-float-charger-62813.html
I turned my key on, and the lights lit up (and since my fan is wired to the switch, it came on.) I tried to start it, but only the solenoid would buzz. I still had to start the ATV with the pull start. I rode it for about 15-20 mins at about 3-4000 RPM, and then shut it off. I turned the key on again, and had nothing...the battery was dead again. Seems to me that after running it even for that short time would have helped charge it, but it drained the battery instead.
The battery is only about 3 years old, but we had an unusually cold Winter this year, so it may have effected it.
I have the repair manual for my ATV, but I get confused on some of the procedures, I guess because everything is in so much detail. Can anyone help me in figuring out if I have a battery problem, alternator problem, or if it's an alternator problem?
Thanks in advance!
Thanks in advance!
