more info on 350 fourtrax with fan problem
the battery supplies 12 volts to the fuse for the fan when the key is turned on, this puts 12 volts to the fan, by using a needle to puncture the GREEN wire at the fan and using a clip lead ground to the motor, the fan will run, normally, the temperature sensor would complete the ground, I did not find a relay or fan module. other information that I found suggested there might be a relay or module but the information was for other Honda models. Hope this might help someone
