Hi. Can someone help me here. I have a honda 350 fourtrax ES 2005 and the electronic shift has all but stopped in both directions. Once in about 50 times it will move the gear selector and then nothing at all. There was recently a flat battery on the bike and it was started manually with the pull start until the new battery was installed. I have read some previous threads and it suggested that the new battery was not powerful enough, but I checked that with another battery and it is strong enough, also, I have tried to access the fault codes but there is no fault code coming up at all. everything else is working fine and the bike can be manually engaged by the auxillary arm that came with the bike when it was new.
Thanks for your help
Since the ATV can be shifted manually and there's no trouble codes, I'm at a loss as to what the problem could be. If you're sure you have a good battery, try adjusting the clutch free play. Also, I would unplug the plug from the angle sensor and make sure it's clean.
Thanks very much for that and I will check everything, Just one thing, wgere is the angle sensor on the bike as i am still learning about it
Thanks again!
The angle sensor is on the front crankcase cover, either beside the shift motor or under the shift motor. I believe it's down under the shift motor, if I remember right.
It will have a little metal cover over it with two bolts holding it on.
