Hi. Can someone help me here. I have a honda 350 fourtrax ES 2005 and the electronic shift has all but stopped in both directions. Once in about 50 times it will move the gear selector and then nothing at all. There was recently a flat battery on the bike and it was started manually with the pull start until the new battery was installed. I have read some previous threads and it suggested that the new battery was not powerful enough, but I checked that with another battery and it is strong enough, also, I have tried to access the fault codes but there is no fault code coming up at all. everything else is working fine and the bike can be manually engaged by the auxillary arm that came with the bike when it was new.
Thanks for your help
Welcome to the forums. I posted an answer in your other thread, but don't know if it will help or not.
go to docsatvservice(dot)com and he has a bolt on hand or foot shifter for the ES models. i have this on my foreman 450 and when i get into the woods it gets me out. And on docsatvservice(dot)com he has a module that bypasses the ES wirings and is direct. i put that on my foreman and now i can go through mud and it will work and the ES has not given anymore problems since. his number is 601-659-9931
