1 - 20 of 32 Posts
I'm looking on diamond j custom's website and I was wondering if anyone had any pics of before and after of either the 4.5" or the 6", or if you have a picture comparing the two. Also what shocks should I go with if I were to do this? What would bolt right up and what would take adapters, ect?
Don't buy the widening kit.They change your caster camber throught the suspension movement and it makes it feel squirly.I took this off but here you go.
I was thinking of buying the widening kit, but now ived read this thread maybe ill postponed purchasing it.
Somewhere on here there is a link to an article that discusses the widening kit and goes into detail about what it does and the effects of it and it seems that it wouldn't be a very good choice. The kit moves the pivot points of the A-arms further outboard from the inner tie rod ends and it causes the plane of the A-arms and the tie rods to be further out of parallel with each other. This causes binding and bump steer and it makes your ATV steer bad.
Well, you changed my mind quick. So I guess it's 400ex a arms. I just have trouble finding them on ebay. Does anyone know who sells them? Also if I get 400ex a arms don't I also need 400ex shocks too?
You can't use the 400ex shocks without the conversion kit to my knowlege
I think you'll need the shock conversion kit.If you use your stock shocks it will just sit lower.
Discussion Starter · #9 ·
Oh alrighty. Lower isn't too bad. I guess a lower center of gravity wouldn't kill me all that much :D . But just to clarify, I would need upper and lower correct?
A a rms yes you would need upper and lower.And there hard to find at a good price.
Discussion Starter · #13 ·
Ah dude I don't have any money. I was just using it as an example. Plus I still don't have the quad. I'm just putting together some research and stuff to see what to, and not to, do when I do get it, but I appreciate the help!
Don't buy the widening kit for any atv you getting or are gonna get.
Discussion Starter · #15 ·
I'm not. But now I'm really thinking about a 400ex instead. I would much rather have too much power than can be controlled than to little that'll cost a fortune to get more
Now your thinking.LOL
Discussion Starter · #17 ·
Found an '02 for $1200. Sounds low but you never know. I REALLY wish I had better luck finding a job. I honestly need to put in more applications.
Well get on it.Don't just sit on the internet and say you need to.LOL
I wish I could hire ya brother... Move to Denver and you got a job. Mon-Thurs. start at 10:00 AM-ish. No weekends, you can have any day off but Monday. Start at $11.50
Can you believe I can't fill this position???
Discussion Starter · #20 ·
I don't see how you can't with all the people who need work. Plus you don't have to get up early! I would take that job, but I'm 16 in high school, don't see how I could work those hours into my day ;)
I would go out and turn some in, but sadly I don't have my car right now so I'm stuck at home
1 - 20 of 32 Posts
