1 - 18 of 18 Posts
So when i got my 300 ex the reverse lever was not on it. so i try to put it on but when i do its like not tight. its just falls to the ground . what do i do?
Did you tighten the bolt? If so, then the splines are probably worn out.
You'll probably have to buy a new reverse lever. The lever has the splines machined on the inside of the hole in the lever. There are matching splines on the reverse shaft that the lever goes on. The splines are the little grooves or notches that keeps the lever from slipping on the reverse shaft.
If the splines on the reverse shaft are worn off, then you will have to have a new reverse shaft also. Hopefully, the splines won't be worn all the way down and you can get by with just buying the reverse lever.
Ok, I didn't understand your question at first. The reverse lever bolts on a shaft on the bottom left side of the engine. Here is a picture of where it goes.
There's a piece that bolts right above the front sprocket guard that holds the reverse lever rod. It's hard to see in the picture below, but it's the little black piece above the sprocket guard.
It attaches up close the the front gear on the case
Yeah, I think that piece is supposed to bolt in that empty bolt hole straight above the front sprocket in your picture.
All it is is a clamp like an Adell style juts to hold it in place any style clamp should work go to the auto parts store and pick on up
Like this
Like this
Yeah, something like that should work, just anything to hold it up in place.
Yep probably just missing the guide.
1 - 18 of 18 Posts
