1 - 10 of 10 Posts
I am replacing the rear end in my 2001 300ex and can not get the bolt off! any suggestions????? ppppppllllleeeeaaasssseeeee!!! Seriously, I'm actualy begging!
If you are speaking of the two nuts that are jammed together they turn opposite of each other but they can be a bear if they are siezed.
do you have the right size wrenches and a set of torches, on that year of a machine if they have not been off b4 those torches will almost be a must. if no torch spray some lube on them and let them sit overnight, those are normal threads but you want to tighten them (turn them toward the rotor) inner one first then out then remove the clip that is out board of the threads then it will slip off. off coarse the chance of it going that smooth is almost unheard of...
Discussion Starter · #9 ·
Yes I have the right tools and a torch but did not know to use it. Thank you and no you do not type to slow.
Discussion Starter · #10 ·
This diagram is wonderful! Thank you so much!!!!!!!! I searched online for hours and could not find one!!
1 - 10 of 10 Posts
