I would just replace the wheel bearings, because you will have to remove them to grease them anyway and you might damage them getting them out. Also, make sure your problem isn't the front brakes catching or dragging.
how do u fix if it is the brakes dragging and how do u take out the berings
It depends on what's wrong with the brakes causing them to stick or drag, but I would check the front calipers and make sure the pistons are seized in the calipers.
As far as the wheel bearings, you will have to unbolt the hubs and knock the bearings out, they are pressed in.
