hows everyone doing ,i got a question, i noticed if i move my handle bars a little bit my front right tire will move about a half inch before my left does what would cause this, thanks in advance for any help
You will be alright for a short amount of time. i have seen some HORRIBLE ones. Make sure your tie rods are tight to the stem. I have had that problem.
yea before i go out again [hopefully in the snow for the first time] ill have my friend look at it, i hit a lot of bad roads with a lot of big rocks so im sure im going to go through this a lot, by next summer ill be able to fix these blindfolded
One thing to check..... my quad was like that once.... where the inner tie-rods connect to the steering stem. remove the cotter pins and tighten the nuts up and reinsert the cotterpins check the play then . You may also want to do the outer the same way..
