Hi, I have a 1996 TRX300ex and am rebuilding the swing arm carrier/axle bearing. I saw online you can buy the entire piece with bearings but I am impatient and wanted today so bought a rebuilt kit from a local Bearing supplier. I believe my carrier is an aftermarket because the old bearings were almost twice as wide as the "stock" ones he showed me.
I have a few questions based on the pic.
1) as part of the kit included (2) #30's in the picture part number 91353-HA2-003 O-RING, BEARING HOLDER (ARAI) I can't seem to find where these go.. they are O-rings flat on one side and round on the other. Would they go here as in the 2nd pic in the grooves on the outside of the carrier?
2) #29 in the picture is labelled as part # 91351-737-752 O-RING, ROTARY CASE and says 1 is required . I can not see where there was this O-ring anywhere on the assembly before. where does this go? and if it's an aftermarket carrier do you think I need it?
Thanks very much for any help
