Monday afternoon I was messing around in my shop and dug out a 300 diff I'd rebuilt. The pinion gear was tweaked a hair, so I'd set it on the shelf and figured I'd put new gears in it at some point.
I had another 300 diff that had a busted case, but had good gears in it that I tore down later, and I remembered thinking "I can use those gears in that other diff"
So as I dig up a pinion gear, slap it in the 300 diff, and put it back together, I find that it spins over nice and smooth, good teeth contact, and then when I get ready to lock up I realize I'd taken a 350D pinion gear and put it in a 300 diff.
So, I know the gear ratio is the same, and I know the axles on a 300 are much bigger around than a 350 Foreman axle, but it looks like the pinion gears are interchangeable.
I'm going to tear that 300 diff back down and compare the tweaked 300 pinion gear to the 350D pinion gear more closely. I'm pretty sure they're the same.
Just something I found interesting since there are no gear kits being made for the 350 Foreman rear ends.
