new valves and valve seals were installed when I rebuilt the top end. After I got back from a WV trail ride. I changed the oil and that's when it started to smoke at cold start up. Checked oil, not over filled or anything like that.
I purchased a new set of valve seals from Honda and installed them. It still smokes at start up. Sometimes its so light you can barely see the smoke then sometimes it smokes worse but clears out after a minute or two.
Checked compression, it is good. When I installed the last set of seals, I check for excessive play in the guides by wiggling the end of the valves, didn't feel any play at all.
