i would like to say thanks to everyone for the help before. i had a carb leak and now dont start. i now have lost compression and think it was because of gas in the oil.there was a lot thining it out would this cause lose of compresion or did i do more damage than i think?if i just change oil is that gonna be good enough ? thanks i appreciate all the help. chris
If you have gas in the oil then you have bad rings or piston problem.
I would put the oil in and start it. If it smokes out the exhaust then you need rings if not run it. And keep your fingers crossed. If you notice any knocks or ticks while riding it shut it off fast.
