i still have not managed to get the thing off.
cliff notes, i cant get the brake drum hub off.
took the nut and collar off, took the 4 bolts out of the back side of the brake drum hub, took the spring off on the inside, bleed out the brakes. got the adjuster wheels broke free (one for each side on the bottom) but they only turn one click before they hit the bracket for the brake shoes, i think that is what that bracket goes too, the shoes.
the adjuster confusses me, on the end of the adjuster its like a fork or so and it slides over the brackets for the brake shoes. a wide fork at that, almost like a flat head screw driver on the top side, and the bottom side of the bracket, sandwiching the bracket in the middle, running at a 90* angle to the bracket i turn it one click up, it hits the bracket, i turn it one click down, it hits the bracket. and when it hits, i cant turn it no more. its almost like its there to keep the brackets just lined up. i tried turning the whole adjuster itself up and down facing so its not even touching the bracket for the shoes, maybe then letting the shoes come in and not push against the drum, but it gets hung on the bracket and i cant turn it that far.
i can stick a screwdriver in and pull the shoes back some but its like its spring loaded (i took the spring out) and goes back into place.
what am i doing wrong, what else could it be?? that wheel had a little bit of wabble to it so im sure the the bearing or something is a little crocked. i took a hammer and pole and beat on the back side of the drum thinking it needed some force but no luck with that.
any suggestions??
any suggestions??
