... the only change I know about between 88-2000 on 2wd or 4wd was in 1998 they started putting a large stainless steel washer on top the seal on the left side the differential , if you have an older rear end that doesn't have this washer and ride the bike in mud then I would get one and install it as an upgrade , I really believe that it helps to make the seal last longer
