Any one know how to remove the rear axle sprocket hub, from the axle. I know there is a wire clip on one side, which does'nt seem to come out, without moving the hub. Thanks guys.
I don't think the sprocket hub is supposed to come off. When you buy a new axle, the sprocket hub will come with it.
Your correct helmut.They come pressed on.Why are you trying to remove it?
TRX250X axle sprocket hub
Alocal guy was in need of the sprocket hub, and I spoke before I looked. The hub is pressed on to the axle. I'm sure it would come of with the proper tools, But I don't have those kinda tools. Probably wind up destroying the hub trying to get it off. Your extemely correct HELMUT thanks.
i have a 91 trx250x and the sprocket hub threads stripped and i got it off. but i spent $100 dollars on a new durablue hub and it wont go on
Welcome to the forums...
That is because the durablue has larger splines and is only made for a durablue
