1 - 11 of 11 Posts
EDIT - Looked it up, the 300ex pistons should work but they are lower compression rating. . Namura piston sets + gaskets for top end were only around $100. If they work well, I may just get that.
Any reason to run the 12:1 versus a stock 300ex compression rating piston? Any detriment against the X running well?
______________________________________________
I have a 250x. Found some parts including a cylinder that has some good scoring and needs a bore and new piston.
All the ones I have found on eBay are 12:1 compression, some don't have C.R. listed but Wiseco number is, and that number comes up as 12:1.
Is this too much for pump gas, stock valves/clutch + springs, and non-hard faced rockers?
Only lower C.R. pistons are std size which I can't use.
Also, any larger piston should be fine with any head gasket, as it's the OD of the cylinder sleeve, correct? Or might I need a larger head gasket with, say, a .40 over bore?
Thanks
wiseco makes a nice topend kit that includes everything you need to rebuild the top I use a 12:1 at .060 bore with no issues you should be fine with your stock springs and rockers.
I saw that, it was maybe $155 or something of that sort. Gaskets, rings, piston, circlips, valve seals...
Sure I will be alright, as you have 1stage 1 cam, High performance coil, jet kit, 400EX carb, K&N filter, FMF power Core 4 full exhaust listed in your sig. I was hoping for even a 10.25:1 or 11:1 max.
I know it's not recommended on my 350X to go more than 10.25 to one without hardfaced rockers, port and polish, jet/exhaust/filter, valve springs, maybe cam.
Didn't find a full .pdf manual (I did see some pictures from your album, thanks!) to see stock compression ratio, but 12:1 just seems real high??? I suppose I can run AV Gas from an airport or something.
are you building a 250X engine or 350X engine?
I have a full PDF of the 350X trike actual honda service manual if you need it. pm me your email. and I'll send it over
Discussion Starter · #5 · (Edited)
PM sent.
Have a 350x trike that's getting fully rebuilt. This will be a separate 250x quad. Later on down the road I may build a nicer 350X engine for my quad, so I'd rather not go all out on rockers and such for the 250 engine. (But I do want it assembled, needs a piston)
Thanks
They made the 300EX compression lower because it dosne't hav a decompression system, 11:1 is about the max for the 300 so you don't have premature starter failure. the 250X has the system so if you can kisk it you can put it in. LOL
Just buy the 250X piston kit. Why would you want a 300EX piston? 12:1 is fine in a 250 even with no other internal mods I gaurantee it. the stock bore for a 300EX is 74mm the stock bore for a 250X is 74mm, the only thing that possibly could be different would be the deck height since the 300 has 5mm more stroke.
you can run pump fuel with the 12:1 or you can run the 100 LL AV fuel I run both depends on my wallet for that day..lol. If you're not planning on boring it and just want to freshen up the engine go to Honda and buy a stock piston.
Wiseco kit 200 bucks everything you need Less the oil.
I have a 300ex and I know this is off topic but I was riding one day and all of a sudden all my top end power was down the drain I can't go more then half throttle with out it loosing power I took the top end apart and the piston is dirty but no wholes or anything the spark plug was pretty "darkened" but that was really it I don't know what I want to do I still want more power out of it when I am done what would you guys do high compression or bite it out
1 - 11 of 11 Posts
