Hi All,
New member here with a 2012 Honda TRX250TM FourTrax Recon. Considering a 2 inch lift kit and larger tires to gain more ground clearance. Most of my riding is on rutted and rocky trails where good ground clearance is needed. From the research I've done so far, I could fit larger tires on my existing rims (11 inch front, 9 inch rear) but they would have to be 25 inch tires. The stock tires are 22 inch diameter, so I was hoping to find 23 or 24 inch tires so they wouldn't rub my fenders and cause a significant power loss. But 25 inch tire choices are more common and they are available for front or rear. I found some ITP Mud Lites, front 25x8-11, rear 25x12-9. If anyone has some experience with 25 inch tires on the Honda 250 Recon, I'm all ears. Plus any suggestions on wheel spacer widths would be helpful. Thanks.
