Having issues after changing the oil for the first time. Please talk me down off the ledge.
- I followed the owners manual
- Took out the Dipstick
- Removed the plug nut and drained the oil
- Replaced the plug nut starting with 10lb of torque, felt like stripping before torque wrench even hit 10lb click, removed nut and found washer was bent. straightened washer and re-tightened. Could be a problem with this nut, but there's no leaking, maybe metal got up in the engine?
- Added exactly 1.5qt of 4 stroke 10w-40, replaced dipstick
Had problems starting up even with choke whereas before oil change, it started like-new
It finally did start and idled correctly. Let it warm up and visually inspected plug nut for leaks.
Rode for 10min and constantly stopped to visually inspect plug nut.
Rode for 15min longer and it started to sputter, then stalled and wouldn't start.
Has Gas, Fuel Line is On.
Spark plug cable is tight.
Kill switch is set to Run.
Unfortunately have made a call to the dealership, is there anything else I can do or check?
